Hi all,
One of the things I like the most when working with a different CFI is the different opinions about things.
Today, we did stalls.
As a student I was thought - pick the low wing with the rudder.
CFI: "Use aileron, otherwise you could enter a spin"
Me: "Adding that rudder is will cause the lowered wing to move fwd, get more lift and raise to normal".
CFI: "On 172's the stall starts on the root of the wing, use ailerons.
Me: "You are the CFI, I do as you say.
What do you guys say?
