How does the temperature and humidity sensor module sense
Fosensor
The sensing principle of the temperature and humidity sensor module is to use measuring elements to convert temperature and humidity changes in the environment into electrical signals, then amplify and digital signal process these electrical signals, and finally send them to the computer for processing and calculation.
Temperature and humidity sensor modules generally consist of two parts: temperature sensing element and humidity sensing element. Temperature sensing elements mainly refer to thermistors or thermocouples, which convert temperature changes in the environment into electrical signals. Humidity sensing elements mainly refer to capacitive or resistive sensors, which convert humidity changes in the environment into electrical signals.
In the temperature and humidity sensor module, there are some other components, such as amplifiers, compensation circuits, anti-interference circuits, etc. The function of these components is to amplify and process the electrical signals of the temperature-sensing element and humidity-sensing element, and eliminate the interference generated by the sensor itself. The error is finally sent to the digital signal processor for processing and calculation.
The working principle of the temperature and humidity sensor module is to use measuring elements to convert temperature and humidity changes in the environment into electrical signals, then amplify and digital signal process these electrical signals, and finally send them to the computer for processing and calculation. This process usually includes steps such as sampling, signal amplification, digital signal processing and output. In a computer, a digital signal processor (DSP) or microcontroller (MCU) is responsible for processing and calculating the collected data, and outputting corresponding control signals to control actuators or regulating devices to perform corresponding operations. The working principle of the temperature and humidity sensor module can be divided into three main stages: sampling, signal processing and output. In the sampling stage, the sensor converts temperature and humidity changes in the environment into electrical signals; in the signal processing stage, DSP or MCU amplifies, filters, and adjusts the collected electrical signals; in the output stage, the digital signal processor performs processing based on The input command controls the actuator or regulating device to perform the corresponding operation.
https://www.hnfosensor.com/product/temperature-humidity-sensor
