phil_at_webfam.org
I'm working on my commercial certificate and ran across this requirement in CFR 61.129(a)(4)(i): "One cross-country flight of not less than 300 nautical miles total distance, with landings at a minimum of three points, one of which is a straight-line distance of at least 250 nautical miles from the original departure point." I've flown numerous trips from my home in west Michigan to NY, NJ, VT, NC, MN, etc. (all far greater than the 250 miles) but I don't think I've made one with three landings in one "flight". In each case I've flown there, spent an overnight, a few days, or a week, and flown back and some of those I've stopped at another airport on the way there or back. So for a specific example does it count to fly 600 nm to Teterboro, spend 4 days, then on the way back spend the night at Franklin, PA, and then return home?
