If the mafia tells you as a store owner that you need to pay their protection demands or they will break your kneecaps
Ha. Too much. We’ve gone from the FAA enforcing the FARs to the mafia breaking kneecaps. Nah, homie doesn't follow that rabbit-hole…
But if you want to stay on the OP topic, perhaps you can post some actual examples of the FAA using threats and violence to enforce their rules and regs? And we'll parse that topic a bit farther....
			Why would this cost any more for a carrier than it already does?
Because there is no cost now due to the US ICAO membership and other bilateral treaties/agreements. Without those agreements, each airline would need a separate national approval/certification from each international country for each aircraft and each crew member to operate in those countries. And those certifications are not cheap and usually must be renewed on a regular basis.
In addition, each airline would be required to pay duties and customs on all aircraft parts and operational supplies they would import into each country which are currently duty-free as the ICAO agreements provide for a “free-zone” at each recognized international entry airport. And so on.
All these additional costs would be further multiplied by the timeframe it takes to comply with these additional country approvals/certifications which in some cases can be measured in months. And if you want an example of what a months long delay would do to the international aviation industry, just look at the results from 9-11 or the covid pandemic.
			If they were doing so without the government involved that is almost always cheaper. The inefficiencies of nearly anything the government does being well established.
So, what are some specific examples of governmental inefficiencies with the
aviation industry and how it would be cheaper? As I noted, the 78 Dereg Act saved money on one hand but cost more money on the other hand and created a whole new slew of problems unheard of prior to the Act. So I don’t quite follow how things would be cheaper with less government in aviation.
			OTOH - the domestic only carriers could drop those items which were not required by their insurers and they did not think served their purposes.
If the US were to drop their ICAO membership and cancel those other agreements, the US domestic only carriers would cease to operate as you know it today. As I mentioned, you don’t seem to fathom how the US aviation industry works and the interconnection between the international side and the domestic side. For example, the effects of 9-11/pandemic were much harsher on the domestic side and would have the same effect, if not worse, as with your plan to cancel ICAO, etc.
Curious. Do you have any personal experience in the Part 135/121 aviation industry?
Or, any personal experience with the Part 13 FAA enforcement process?
Or any personal experience with obtaining other type FAA operating certificates or approvals outside your private pilot or CFI certificates?
