Strange Skew-T sounding
Everskyward
I was reading the thread about the inversion in Nebraska where Jesse posted the sounding. On a whim I got the local current sounding and it looks like this.
How does that happen, with the dew point to the right (greater than) the temperature? Or is this an error?
Everskyward said:
My guess is that it would be this supersaturation relative to ice. I have known for a long time that this occurs but it never dawned on me what it would look like on one of these charts.
Why ice? I notice the graph shows a temperature of over 20 C at 20,000 ft. Also, there is quite a large jump in temperature at 15,000 ft. I'm not sure what to make of all that.
I wonder if the Colorado fires cause some unusual readings if the radiosonde passed through the smoke?
azure said:
Where do you see a temperature of 20 C at 20,000 ft? It looks to me more like -10 C.
Also, the jump at 15,000 ft is in the dew point (temp = thick red curve, dp = thick blue curve).
Oops! I made two errors - reversed the lines and used the wrong axis for temperature. I obviously misremembered how to read skew-t charts! :redface:
scottd said:
Nope. This is something that can occur in the RUC analysis, and is specifically caused by the cloud analysis in the model. This can happen while trying to conserve a parameter in the model called theta-v. The temperature is reduced and can "overshoot" the dewpoint, resulting in what appears to be supersaturation.
Thank you for the correction and explanation.
scottd said:
The Skew-T presented by the OP is from a model analysis, not from a rawinsonde observation.
Is it a rawinsonde or radiosonde? I had learned the latter term decades ago, but have to admit first seeing rawinsonde only a few years ago. (First time I saw it I thought it was a typo.) I see the definition at Wikipedia seems to indicate the equipment on a balloon used for Skew-t observations probably makes them radiosondes rather than rawinsondes. However, I've come across incorrect information on Wikipedia technical articles a little more often than I think should be the case.
