Is there a law against using the Air Force 1 callsign during flight? For example, should I fly into an airport and report up "Air Force One, inbound," have I broken a law.
If you used AF1 and not your own ID you'd be in violation of the above reg. If you used your proper ID and AF1 I'm not sure of the reg you'd be violating, but it would be in the FCC realm and probably not the FAA.
