The following interesting concept is likely to blow the mind of not only those who can't grok the plane on a treadmill problem, but many others. This video basically shows a ground vehicle that captures the wind using a prop that drives its wheels and accelerating to a speed directly down wind faster than the wind:
The initial reaction of most people is likely to suspect a fraud - after all - once the relative wind drops to zero, surely the force on the prop drops to zero and it can't travel down wind faster than the wind?
However, since this device isn't hard to build (there are plans and other videos on the net) and has been established, the next thing is to figure out where one's physical intuition has gone awry. Here is one video I think does a good job of first showing how a wind (represented by the ruler) can drive a prop (represented by the big wheel) can make a vehicle caught between two co-linear planes travel faster relative to one of the planes (the ruler) in the reference frame of the other plane (the table):
I think the concept is neat precisely because the vehicle is a simple mechanical device, yet its behavior appears contradictory and takes some time to comprehend what is happening.
P.S. A sailboat can't sail faster directly downwind than the wind - though it can tack across the wind and thereby sail faster than the driving wind speed - but if the sail was replaced with an air prop geared to a water prop, then the boat could be made to travel faster downwind than the wind.
