I guess I will have to lay it out in explicit detail then. Here is my quote which you likeRyanB said:Unless I’m just interpreting it other than face value, that is essentially what you said.
You then paraphrased asBut the argument that the fact there have been no major attacks since the inception of the TSA implies the TSA works is not supported by the numbers.
So my statement was there is an argument "The fact that there have been no major attacks since the inception of the TSA implies that the TSA works". I then further stated that argument is not supported by the numbers.“There hasn’t[sic] been any major attacks since the inception of TSA, so that implies their organization isn’t very effective.”
Let the assertion that there have been no major attacks since the inception of the TSA be X. Let the assertion that the TSA works be Y. The argument could then be cast abstractly as X implies Y. I said that argument is not supported by the numbers, in these abstract terms, it is not true that X implies Y (or that is not supported by the numbers).
You then paraphrased that as
That argument, which you attribute to me, in terms of the same variables, would be X implies not Y."There hasn't [sic] been no major attacks since the inception of the TSA implies that there is organization is not effective".
Does that help explain how there is a material difference between the paraphrase and the original statements? If not, here is a further explanation using the rules of logic.
The rules of logic are that saying 'X implies Y' is false is the logical equivalent of saying its contrapositive, namely, 'not y implies not x'. (https://en.wikipedia.org/wiki/Contraposition) In concrete terms here that means my two statements would be the equivalent of "If the TSA does not work, then there there may have been major attacks since the inception of the TSA". But you see, I did NOT say that either.
Your paraphrase, improperly attributed to me, is abstractly 'x implies not y', which is the negation of my assertion. Of course I would assert it is false, as it is the negation of what I said.
And such misattribution is a classic example of the straw man fallacy.
The book "Game of Logic" by Lewis Carrol (author of Alice in Wonderland) is a fun way to study these things.
