MauleSkinner said:
Key wor here...the airplane must RETURN to within the appropriate tolerances of the original airspeed. Going from full power to no power will result in the airplane slowing down, and assuming it's got enough altitude and time, it will work its way back to the original speed. There will, however, be large changes in airspeed before it gets there.
Power is reduced or cut on every landing. Do you recall ever experiencing dramatic slow downs requiring you to push the nose down? Don't you actually find you have to pull back to slow up because the plane continues to fly at the trimmed speed of its own accord? I should have also quoted the Part 23 requirements for dynamic stability (below) in addition to the static stability requirements. You'll note that it requires heavy damping of phugoids with controls free to move or fixed in place.
Different planes will react differently so of course it is worthwhile to experiment at altitude: apply takeoff power, trim to Vx or Vy climb speed as one would on tskeoff, then cut the throttle and don't touch the elevator. I believe most pilots will observe the nose of their airplanes to simply drop on its own and the speed oscillations to be modest and short lived.
§ 23.181 Dynamic stability.
(a) Any short period oscillation not including combined lateral-directional oscillations occurring between the stalling speed and the maximum allowable speed appropriate to the configuration of the airplane must be heavily damped with the primary controls—
(1) Free; and
(2) In a fixed position.
(b) Any combined lateral-directional oscillations (Dutch roll) occurring between the stalling speed and the maximum allowable speed (VFE, VLE, VN0, VFC/MFC) appropriate to the configuration of the airplane with the primary controls in both free and fixed position, must be damped to 1/10 amplitude in:
(1) Seven (7) cycles below 18,000 feet and
(2) Thirteen (13) cycles from 18,000 feet to the certified maximum altitude.
(c) If it is determined that the function of a stability augmentation system, reference § 23.672, is needed to meet the flight characteristic requirements of this part, the primary control requirements of paragraphs (a)(2) and (b)(2) of this section are not applicable to the tests needed to verify the acceptability of that system.
(d) During the conditions as specified in § 23.175, when the longitudinal control force required to maintain speeds differing from the trim speed by at least plus and minus 15 percent is suddenly released, the response of the airplane must not exhibit any dangerous characteristics nor be excessive in relation to the magnitude of the control force released. Any long-period oscillation of flight path, phugoid oscillation, that results must not be so unstable as to increase the pilot's workload or otherwise endanger the airplane.
