Well, the lawn tractor that I received for free (from someone else who received it for free) finally broke the mower deck. Not only did it break the spindle (a simple enough fix), but the mower deck itself is actually broken where the spindle can't attach properly.
I could weld it back together and it would probably last for at least a bit. However, it seems most likely that we should just get a new mower. After all, this thing doesn't owe us anything, is old enough that nobody stocks parts for it, etc. The engine runs pretty well, but the carb needs to be worked on as it's running too lean.
We've got about 2 acres to mow. What would be really nice would be an option that would also allow us to attack our steep hill, which right now we've been having to do with a weed whacker or the push mower. Our previous mower was a 46" riding mower, which was sufficient, but bigger is always nicer.
A pull-behind is not out of the question, as I could get this tractor itself working fine pretty quickly with a bit of carburetor work. I haven't had any luck finding a new mower deck. I've also been intrigued with the gang-reel idea, but those seem to not tolerate hills very well and be very finicky from what I read.
Any thoughts or suggestions on good brands, etc.?
