Starship explodes after takeoff
I am not so sure that is a good advertisement for a rocket that you want to have customers pay to ride on. But it was exciting…
It exhibited the same problem during the one static fire test: failure of several engines.
I suspected something wrong by the slow acceleration on launch because the thrust to weight ratio is supposed to be higher than the Saturn V.
Interesting. Back in the 60s the Russians also used many engines in their big boosters. While the Saturn V had only 5 F-1 engines, it was sort of a clever trick, because each engine was divided into 13 compartments with baffles to stabilize combustion.
