Scrabo
Member
From the iTune store...
What's New in Version 8.0.0.0
A lot of V8 power in this significant update and a lot of new features and improvements - here are the highlights including a vastly-improved routing engine with easy editing even if you have fat fingers. This new routing engine with fully selectable DP, STAR, and IAP entry is the primary reason this release took a little more time than other releases:
Two more iPad firsts for WingX Pro7!
● Instrument Approach Chart routing
● WingX Pro7 for Pebble
● Instrument Approach Chart routing - an iPad first - select an approach and WingX Pro7 adds the fixes to your route
● DP, STAR, and IAP routing - add DPs, STARs, and even IAPs to your route - you select the transitions (at both ends).
● New routing engine required to handle DPs, STARs, IAPs, and Airways. WingX Pro7 displays the sections of the route in different colors; DPs are green (as in go), the route is magenta (as previously), the STARs are blue (as in high up, sky...), and the IAP route is red (as in caution).
● Display route by Summary, Turns Only, or All Points
● WingX Pro7 for Pebble - an iPad first - view your next waypoint and destination information such as ETE, ETA, DTK, NM on your watch! You can also set a timer (for fuel for example). Oh, one more thing, WingX Pro7 for Pebble will vibrate when you are 1000' above the destination elevation to remind you to run your checklist! How cool is that?!? Oh, you can even monitor your iPad/iPhone's battery level.
● User-Documents - display them in WingX Pro7's split screen (or full screen) - for example, a sectional on the left and the POH's checklist on the right
● Moving Map performance improvement - lots of new work 'under the hood'
● Remove Auto-N functionality in DUATS, now users enter the N-prefix or not as required
● New-look (much better for night), but we're keeping the same easy-to-use and sparse user-interface.
● Added "Split" button that alternates between full Route column, full A/FD Column, or 50/50 of each (as before).
● Fixed DUATS issue
Note: We have renamed the GeoRef Subscription to the Advanced IFR Subscription. It is just a name change that incorporates the new IAP routing. There is no price change and if you have a current WingX Pro7 georef subscription, you will automatically have a current Advanced IFR Subscription because it is the same thing, just a name change to be more applicable to its function.
● Fixed DUATS issue
