poadeleted21
00W has served me well but my training mission for it is nearing completion. Would make a good plane for primary through instrument training. We've taken it all over the PNW on cross countries too.
Time to burn more fuel and pay more for insurance.
Haven't calculated the times lately but Approx 700SMOH 6300TT
The 150 is similar to a 140 with the most noticable difference being that it has a factory baggage door and no hat rack.
In the last 2.5 years, off the top of my head.
New engine baffling
All new hoses (oil cooler, fuel, etc..)
Rebuilt Mags
New tires
New airtex carpet.
new wall panels
new DG
new AI
new VSI
new KI202 CDI
new AK650 annunciator
new Alt Encoder
new filters.
new boost pump
Avionics
KLN89B IFR Certified install
KY197
KX155 w/GS
Narco AT150 w/Encoder
PS Engineering integrated 4 place audio w/ dual PTT (and ISO switch)
KMA Audio Panel
AK650 Annunciator
Transponder recently checked but IFR certs just ran out last month.
4cyl EGT
LC-2 Clock timer (wired in)
Interior
New Airtex carpet
New wall panels
Serviceable seats (don't quite match, hardly noticeable but they're in 8/10 shape)
Could use a headliner
Plexiglass is servicable but has some crazing and a stop drilled crack on the door window.
Exterior 7/10 paint is all there and not faded but it doesn't shine as well as it used to. I have the wheel pants, I just leave them off for the winter.
Engine (Lycoming O-320) approx 700SMOH no leaks, good compression on all cylinders (Millennium cyl.) and runs strong.
Propeller is fairly new and in great shape (Approx 200hrs on it I think)
Annual due 12/2012
Static Test Certs Expired 5/2012
Transponder Test Current, performed, new encoder installed 02/2012
The Bad
Very old damage history (1960s)
Corrosion history that was corrected approx 7 years ago.
Seems the left side fuel sender float has a hole in it (we verified it was working, it just slowly sinks to the bottom) making the left fuel level gauge indicator not so trust worthy. (Will be corrected at next annual if not sold first when SB1006 is complied with)
could use new plexiglass
Sometimes the ASI bounces at about rotate speed on takeoff, pitot/static system needs cleaning. (going to have this looked at when I renew the IFR certs soon)
A couple of the EGT probes are inaccurate.
Asking $23,000
New engine baffling
Rebuilt Mags
New tires
New airtex carpet.
new wall panels
new DG
new AI
new VSI
new KI202 CDI
new Alt Encoder
new filters.
new boost pump
Avionics
KY197
KX155 w/GS
KMA Audio Panel
AK650 Annunciator
4cyl EGT
Interior
New Airtex carpet
New wall panels
Annual due 12/2012
The Bad
Asking $23,000
