Gene Whitt was an experienced pilot who used to post to the Usenet aviation newsgroups. He had set up his own web site with a lot of wisdom and insight he had gained during his years of flying, though he passed away a few years ago. His web site eventually vanished too. Fortunately his writings are preserved on archive.org. I thought the following would be of interest to fliers of the Cessna C-152 and C-172. Maybe even the C-182. I found his insight useful while flying the C-152 and thought others might find it useful.
Quoting from https://web.archive.org/web/20080208114402/http://www.whittsflying.com/web/page5.62C-152.htm
Last week (9-7-99)I failed a checkride at a certified Cessna Agency in a C-152. I was surprised to find out that with judicious use of initial trim setting for takeoff and power, it is Cessna's standard instructional procedure to negate any use of trim. The C-152 can be leveled from climb at 80 knots just by a reduction in power to 2200 rpm. No trim necessary. The abeam the numbers reduction of power to 1600 and the first ten degrees of flaps gives an approach speed of 70 knots and power at 1500. No trim necessary. The addition of flaps in the turns gives sufficient lift/drag to make this one power setting applicable for the whole descent. The base turn is accompanied by the second notch of flaps. Result is an approach speed of 65-knots. No trim necessary. The full flap condition is applied in the turn to final and the speed drops to 60 knots for the final approach. Keep 60-knots into the roundout and flare at 54 knot by keeping the nose slightly below the end of the runway. By letting students see where they are going we keep them from being frightened..
Insult was added to injury when I found that the C-172N could be flown and landed the same way. according to Cessna I have been flying their aircraft incorrectly for over 30-years. Even my first instructor, who became a factory representative for Cessna, taught me incorrectly by emphasizing the use of trim. This old-dog has learned a new trick. Oh, lordy, I have seen the error of my ways and have a ton of repenting to do. Where was Arenias when I needed him?
